964 Forum 1989-1994
light weight wheel
Old Apr 18, 2009 | 05:33 PM
Solitude's Avatar
Solitude
Default light weight wheel
I'm looking for the best OEM wheel for my DE,track 1991-964. Performance and weight is more important than looks. I do not understand much about wheels so please keep it simple. If possible, part #s will be best. Thanks
Old Apr 18, 2009 | 10:38 PM
Colin 90 C2's Avatar
Colin 90 C2
First you have to determine what size you want. Your options are 16", 17", 18" and possible 19".
the 16" will be the lightest along with the lightest tires.
I realize that there are some ultra lightweight larger wheels, but they are expensive.
You will add unsprung weight as you go bigger and will suffer a performance loss that may be offset by better grip.
I just went back to a 16" wheel tire combo from a 17" wheel combo. I can definitely feel the performance difference, besides getting a smoother ride.
I have a set of 16" Cup 1 for sale, if you're interested.
good luck with your search. there is a lot of great info out there.
Old Apr 19, 2009 | 12:11 AM
Nine11's Avatar
Nine11
Why OEM? There's a lot of lightweight aftermarket rims that fit the P car.
Old Apr 19, 2009 | 03:08 AM
Solitude's Avatar
Solitude
Looking for 17" or 18". Does not have to be OEM. Just trying not to get more confused.
Old Apr 19, 2009 | 03:18 AM
Nine11's Avatar
Nine11
Do you have a price in mind?
Dymag
Forgeline
CCW
BBS
Volk
They make some lightweight rims....
Old Apr 19, 2009 | 07:43 AM
tony.t's Avatar
tony.t
The early 996 17ins wheels fit (although you might need small spacers _ I had them on my C2 but it was some time ago now). OEM wheels, they weigh about 19lbs IIRC and are cheap to buy used.
Old Apr 19, 2009 | 11:26 AM
Solitude's Avatar
Solitude
It will be for track use and not get much wash. So looks is not important. Need the best bang for the buck with weight factor considered.
On the 996 17", is there only 1 kind Porsche made? Thanks.
Old Apr 19, 2009 | 06:12 PM
Nine11's Avatar
Nine11
I have the 996 10 spoke rims...they're quite light.....
Old Apr 28, 2009 | 02:42 AM
Solitude's Avatar
Solitude
On the 996 17" is there only 1 kind? What's the weight of it? How much do you want for it? Thanks.
Old Apr 28, 2009 | 06:40 AM
newsboy's Avatar
newsboy
The 17" 996 Turbo twists I'm running now, weigh less than the 16" Design 90's I use for my winter tires.
Old Apr 28, 2009 | 11:25 AM
earlyapex's Avatar
earlyapex
I have a set of Cup II's that I no longer use on the track. I sent you a PM.
File Type: jpg
Old Apr 28, 2009 | 12:17 PM
Nine11's Avatar
Nine11
I like the rims, I'm not selling. Sorry for misleading. 996 cars have a lot of different rim designs/options that fit other Porsches.
Old Apr 28, 2009 | 11:35 PM
mojo747's Avatar
mojo747
Get some lightweight 5 spokes.
File Type: jpg
Old Apr 29, 2009 | 02:23 AM
Cupcar#12's Avatar
Cupcar#12
BBS E88's
i'll see if i can post some pictures tomorrow
forgot to add Pricey though and basically "stock" if you count Motorsports
Old Apr 29, 2009 | 02:30 AM
Cupcar#12's Avatar
Cupcar#12
adding something
for stock wheels - check out
http://www.wheelenhancement.com/index.php?t=Wheels
also the 16" Cup 1 wheel is actually called the C2 5 Spoke not cup (porsche speak as well as on the site) it is lighter but the generally heavier tire makes that a moot point.
the Flat Dish 16" is the only Forged 964 wheel (outside of the 964 C4 Lw Mg wheel i believe) that was offered for the 964. it's a nice wheel actually.
Boxster and cayman wheels can fit as well (986 is direct, 987 call them..) so that opens up your choices. figure out what you want and if you can deal with used look on ebay/ etc for a used set (perfect for the track)
my 2 cents....
