964 Forum 1989-1994
Rear caliper removal?
Old Apr 19, 2009 | 01:26 PM
jimq's Avatar
jimq
Burgled
Originally Posted by TR6
.............. Sounds like everyone has found this bolt to be a bitch to get off. Maybe I'll take another stab at it.
A LARGE breaker bar pipe is your friend. Mine is 3 feet long and heavy 1" pipe
Old Apr 20, 2009 | 01:03 AM
TR6's Avatar
TR6
Yeah, but I start getting nervous when I'm seeing the whole car shift on the jacks from the effort.
Old Apr 20, 2009 | 01:20 AM
dfinnegan's Avatar
dfinnegan
+1 on both comments . . . 3' long cheater bar . . . and getting nervous watching the car move. In the end, it broke free; after some bouncing on the bar.
Oh, and do not wrap your hand around the cheater bar!! Stand on it. Mine hit the ground rather hard and fast.
The real b*tch is the right hand side. That one you have to lift up and into the bumper; at least that's how I did it. Fortunately that one came free much more easily for me.
Old Apr 20, 2009 | 02:48 PM
Rally Guy's Avatar
Rally Guy
For the right hand side - if you're not on a lift - you can lower the car onto the bar, the end of which is sitting on a jack stand - CAREFULLY - and pop it loose that way. Worked for me perfectly.
RK
Old Apr 20, 2009 | 07:54 PM
Duck's Avatar
Duck
On the right side, I used a jack and jacked up on the breaker bar - worked perfectly. On the left side, never could get good leverage. Finally ended up striping the hex bolt on the left side and had to have it drilled out and $400 dollars later.
Old Nov 16, 2023 | 02:40 PM
Heritages's Avatar
Heritages
Oh you guys rock. I sat in my garage last night trying to figure this out and just gave up. Going to go give it another try tonight. Cheers boys!!!!
