Centre console removal
Hi,
I am currently trying to remove my centre console.
I have removed all the screw around the handbrake area and behind it and now the console lifts up fully at rear and middle however near the front area at the hazard switch etc there is something else holding it??
Can anyone advise me on what you have to remove at front to lift clear?
Thanks in advance!
Stuart
Porsche inspector within UK for Peter Morgan.
http://www.porscheinspections.com/
964 turbo-Rebuilt using ARP hardware and other mods.
Thanks in advance!
Stuart
Stu
Couple more screws behind the hazard/central locking switches.
Pull the panels holding switches out carefully and you'll see them.
Also, may be two on the side of the carpetted bit that heads under the dash
Rob
Rob
Cheers!
Had tried to pull switch panel back previously but felt it was really tight amd may break!..will try again.
Thanks.
Stuart
Thanks.
Stuart
