radio ga ga,,(wiring nightmares)
Hi,
I bought my 964 with a none working radio, so I knew I would have fun trying to get it working again as the gremlins have been messing around in there.
I removed the set and found a real bunch of wires all over the place and not wired to my standards so can I please pester you all again and ask some stupid questions.
I need the colour codeing for all four speakers and the main power cables etc as its not good what the previous owner has done.
I can see the ariel and a black cable loomed together which is the power for the ariel.
Then there is three others coming from a seperate loom,and then the rats nest of speaker cables to sort out.
Thanks for your help in advance Gaz
ps, it will end up on fire if I don't rectify the previous owners D I Y' ING
Thanks for that snippet of information,but please someone on here must be a wiring guru,,,
I KNOW HOW TO FIND A PERMANANET AND SWITCHED LIVE,but please give me the function of the wires as I have explained as I want to do a quality job myself and not a botched attempt like the previous owner.
Many thanks in advance Gaz
ps, I have searched and the 964 companion doesn't give that info.
I no longer seem to have the link, but some guy on the PelicanParts forums posted a "decoder" for the radio wires. You may want to try searching over there.
Thanks for that info will search pelican forums,,
I thought loads of people on here would have had radio problems,as most 964's
have changed hands several times and I haven't seen many cars with tape decks in them.
Thanks for any info Gaz
http://crutchfield.custhelp.com/cgi-...p?p_faqid=7170
I think that may be what you are looking for.
Hi,
Thanks for that link,its the info I needed as the previous owner had fitted the euro plug as its known ,ie the block that plugs into the loom,but I will remove his crimps and re-solder all the electrical joints and double take his wiring connections as its not neat enough for me.
Thanks everyone for all your help Gaz,
