'89 Cruise Control
Yesterday I purchased an '89 964-4. It would appear that the cruise control is not working. Does the cruise system need to be "switched on" somehow before the control stalk to be active? If not, what/where are the components that need to be checked in order to troubleshoot the system?
Thanks in advance
Tim
'89 964-4
'73.5 911T Targa
Thanks in advance
Tim
'89 964-4
'73.5 911T Targa
Mine works intermitently. The shop cleaned the control module for me at my last service because it didn't work at all. It needed a new cable too. The new unit is high so I'm living with it for now. They are prone to corrosion.
Some notes that I've saved:
Best of luck getting it sorted!
Code:
Cruise Control troubleshooting
What I have gathered is that the most common reason for the failure is
the Brake light switch under the pedel assembly, then the clutch Pedel
switch.
Further check the control arm linkage at the throttle area . Then you
need to check the speedometer conection on the back of the
spedometer. Then the computer controler under the console.
