928GTS (front) calipers w/ 964 4 pots rears ?
Bill,
So you consider front S4/993 n/a (med. caliper) over 304 mm. rotor & rear 964 C4 caliper over 299 mm. rotor as a viable mix, assuming no bias valve ?
To get back to the norm for 911/930 you will want the 993 rear calipers. And yes even remove the p/v.
