Autothority Mass Airflow Sensor Q.
Hi,
Do you know if Autothority Mass Airflow Sensor kit deigned for 1992 works on both aluminum and plastic intake type of engines (MY90)?
Thanks,
Daniel
Thanks,
Daniel
The MAF sensor itself should work, however the software on the chip should be different between early and late DME. In order not to support two chip/software products, many use the same software for both early and late DME. It works, the car runs, but this is not the best approach.
