Question
Question
Where would I find the fuel pump relay? I understand I should remove this and crank the car a few times prior to starting it? Its been in the garage, not driven for about 3 months. Would this be the general concensus here or just fire it up as is?
Thanks in advance!
Derek
Thanks in advance!
Derek
Agent Orange
The fuel pump/DME relay is in the fuse box in the upper left hand side of your front trunk. Once you open the the fuse box, look on the inside of the lid and you'll find a diagram with the specific relay locations.
However, since it's been only 3 months, I wouldn't worry too much about it. Just fire it up and drive
Well my RSA goes for months at a time without being started when it's in the garage up at the track. Connect battery, start, check tire pressures, roll out onto the track............
