Air Box - I'm going to cut!
#32
#35
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
i'll post a pic this weekend of my cut box - basically i got this biggest rotary type cutter i had (100mm diameter maybe) and drilled as many holes as i could into the side of the air box - i squeezed 5.
#36
I know I might be a bit late to the dance, since you've already cut the box, but another alternative is to remove the snorkel/trumpet/horn attachment. This seems to work well with an increase in induction noise, seems to keep the wet and debris out and allows you to go back to stock if you have to.
#38
I went for the duct tape test yesterday....The sound improves at around 4k rpm and especially at W.O. throttle which equates to a few seconds of noise before shift. If I get addicted to that sound my gas mileage is going to really suffer. On a side note it was 26 degrees F. yesterday and I thought I had warmed up the car but when I tried to drive the car back fired acouple of times and there was an immediate loss of total power? I tried feathering the throttle but it still just had no "go". This has happened a couple of time before but seemed to warm up and go away? I waited a minute and then went pretty fast in reverse, stopped, and then the car ran fine?? Upon reflection I thought of two thing: I might have ham fisted the shift lever and tried to start in 3rd gear or I am only running one distributer as that thread really spooked me. That blower housing near the lower distributer is a rubiks cube and I had real problems putting it back together when I noticed it was detached. Any thoughts
#39
What I did might be more hokey than duct tape, but at least it was more work.
I didn't want to mess with my air box, but I wanted something more long term than tape.
Anyway, I LOVE the sound.
#40
Professor of Pending Projects
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
So you made your own version of the cup cover. Nice. Can you take another photo, a closeup of the clips?
I have a K&N filter if anyone wants it. Found it again while cleaning up the garage... I have been using factory filters for a few years now as I don't think that having the additional maintenance on the K&N is worth it.
#41
Awesome thread btw, I was looking for info on this.
Bill, can't wait for pics of your cut airbox, as I've been trying to get my hands on an extra to do the same.
A friend told me if I leave the airbox open with the K&N Filter, you'll end up cleaning it a lot more than usual. Sounds logical, but what'd you guys think?
#42
I had a cone filter and reverted back to the OEM air box (no holes) & filter based on comments that the filter oil used on most cone filters may have a detrimental effect to the engine based on oil analysis. Can I tell a difference? No, just less noise and its much easier to wash/detail my engine bay with the OEM air box. I would like to find another air box with holes to play with though
#45
is the induction roar a whole lot louder with either a) just the trumpet removed or b) the box side cut ala cup cars ?
ps...looks like the garage monster has been chomping on your airbox
