Speedo not working...but with comedy-style temporary fix
Hi,
The speedo on my 1990 C4 sometimes fails to work...but if I gently give the glass of the gauge a few "taps" with my knuckle (much like you might knock on a door) then it springs back into life and will continue to work until the end of the journey.
Passengers think it's most amusing that I have to resort to quirky things like this to get my old car to work :-)
Anyone heard of this before or know what might be at fault?
Sometimes it works fine right from the get-go and doesn't require any manual intervention...so it's an intermittent problem. There are also no warning lights associated with it.
Before I pull the gauge out to look at the connections on the back I'd like a vague idea of what I should be looking out for.
Thanks,
Adam
Thanks,
Adam
Adam, I had a similar problem with the OBC tacho on my 964. Took it out checked all the joints on the rear with a small wire brush and a sqeeze of WD40, slotted it back in - Problem solved
Adam,
I'm not 100% convinced by this - but I had a similar problem some time ago where the speedo refused to work (and the rear spoiler woiuldn't come up because of it) and I had other symptoms of the classic "bad solder joints in the clock" issues. Once I'd resoldered the clock joints the speedo problem never occurred again.
I wonder if your rapping of the speedo just causes enough vibration in the clock to overcome the problem?? It's just a thought.
Regards
Dave
Regards
Dave
I've just developed the same problem and was about to do a search on the list to find a fix.....speedo coming and going for no apparent reason....quick rap and it gets better.....and...I put the car through a car wash 3 days ago just before it started.....is it worthwhile just watching and waiting (ie does it get better on its own if it is associated with a recent wash), or should I take it out and resolder all the bits on the back etc. As an aside....its varying between 32 and 41 degrees C in adelaide at the moment, so if it is a moisture problem in the car, it'll dry out pretty quick !
Mark
Mark
apologies for the hi-jack
Burgled
unplug and replug in the connectors on the wheels. It could be a bad contact or if the sensor came loose from thepad it may have worn thru and caused the light.
