Clutch and engine oil
Hi Guys,
To replace the clutch on a 964, would I be right in saying that they would have to replace the engine oil ?
Cheers
Sunil
Cheers
Sunil
IHI KING!
If you are removing the engine, yes then you need to drain and replace the engine oil. Do you have a C2 or a C4? Normally, you drop the engine to replace the clutch. Its possible to do it while the engine is in the car but only on the C2's.
