Urgent Help
ABS and PDAS lights is on
The two hydraulic systems don't share anything other than the reservoir supply
Note the line from 5 to 7; bomb to master cylinder
Took off right front speed sensor
Speed sensor is a good hint. It wasn’t dirty, I just wiped it off, some lube, and back in. I’m afraid that I turned the wheel hub with out the sensor a couple off times, so it didn’t go in at the same position!! Could that really course a problem?
Poleman
Please pull the cable connector to the ABS computer .
Then take it for a drive and see if the funny brake "pedal has a wavy feel" feeling goes away .
Go very slow and be ready with the parking brake . Don't hit anything please .
Pulling the plug on the abs computer kills the abs system .
If the problem goes away , then we will look at the abs system .
If pulling the plug on the abs computer has no effect on the problem ,
we will then know the problem is not in the abs system .
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
It´s midnight here now, the wife just came back from work....smelling good. I make a test drive, first thing to morrow morning with a disconnected ABS....
Have to connect somesthing else now...
Wife that smells good vs broken car in the middle of a cold dark night ?
Good call !
Have you looked to see if the wires / connector on that sensor are all connected real good ?
Have you gone back and rechecked that ?
Good call !
God morning……
After checking all the speed sensors, I made the test drive….still a wavy brake pedal. I still have both warning lamps on. Also the battery warning lamp is on. If there is low voltage, (car starts rapid) can this be the reason for the brake system to failure. Manual says that the blue wire or D+ from battery to alternator can be broken. Maybe something happened since it was a very snug fit when I reassembled the alternator in place. Is there any chanced to measure with out the breathtaking job off disable the hole alternator again?
IHI KING!
If your alternator light is on, I would check your voltage at the battery, with the engine running and with it off. You should have 12 volts when off and between 13-14 volts when idling.
If the voltage is low when the engine if running, then you either have a failed alternator or a loose/broken wire in the charging circuit.
FINALY…..the car is responding. PADAS, ABS and alternator warning lamps are gone. My mistake was when I changed the alternator. In my garage I didn’t had enough light when I connected the wires, and mixed up the ground wire. Luckily nothing seems to have happened with any other components. Brake pedal feels good, but I can forget my test drive tonight…..When I was back home after a nice walk by the see (a must for the Wife), the lovely woodman had paid us a visit …….Not a chance I will move that to the wood storages now! Have to bribe the kids tomorrow!
