Battery Killer
I have a 90 964 C2 and about every 3 months I have to replace the batery. It has a 36 month warranty so the swap is free but its a PIA. I can't find an abnormal drain and I have removed each fuse and replaced and still no clue.
Any suggestions?
Any suggestions?
Sometime the interior light button on the drivers door sticks and casues a constant drain. Check that. A kill switch will eliminate the PITA when not in use shut the battery off and turn it n when you want to use the car.
I have similar problems. I've eliminated most of the usual suspects. My current best theory is that it's a sticky solenoid in the driver's side door locking system, which would explain problems I'm having there as well.
To keep the battery fresh, I bought a Porsche battery trickle charger that I simply plug in to the cigarette socket every time I park the car in the garage.
Cheap solution - doesn't fix the problem but prevents the battery from discharging. The only negative is that you need to reset the clock:
![](http://shop.fvd.de/shop/picture.php?VID=4219687&VCD=20274963&AM=1&SM=1&LM=1&mode=img&action=big&name=FVD612002_2.jpg)
