Has Guards Red ever changed hues??
Just kinda curious.... Parked next to an 86 911 that I could only assume was Guards Red and his looked a totally different shade of red than mine
Would '86 guards red be a different shade than '91 guards red???
Rob
Rob
I think I read in a Up-fixing that Porsche changed suppliers a few times and the result was obvious. Then the factory changed from a two-stage?? to a clear laq. or something like that that increased the difference.. and that dealerships had issues matching the colors.
There were no computer analysis so it was all done at best guess...
I think in the early 80s most paint suppliers stabilized the differences, I know for sure that even the Ferrari "Red" is in the 10th+ incarnation...
I've heard (from the internet, so take it for what it's worth) that die hard fans were a little pissed when Ferrari F1 cars went to the current "day glow" red...
The other day I parked next to a '76 that was exactly the same color as mine, but now looking at the picture I'm not sure...
https://rennlist.com/forums/showpost...&postcount=138
I bet Oracle's right... Anyone know anything else about this?
And the earlier paints faded in strong sunlight more than the modern ones with laquers containing filters. Further the red on plastic, for instance the rear bumper, faded more quickly to an orangey red, mine did and after a respray the difference was very noticeable.
"Guards Red" is over used to describe several similar red colors that Porsche used, particularly Signal Red used for 356s and early 911/912s. Porsche changed the standard non-metallic red color several times from the early 911/912s to today. Then, of course, there were the optional paint colors available and the special PTO colors.
From: Seattle xburb - I can't see the Emerald City, but I know it's out there somewhere
Even on cars that share the same paint code, I'm not sure if I've ever seen two "Guards Red" car that looked exactly the same. This pigment seems especially susceptible to differences in UV exposure and even aging. You can have a GR car with seemingly no oxidation compound cut, and it will look a completely different shade.
Right, I missed his point about '86 vs. '91. It should be the same GR formulation.
