Finally a two-post lift for low ceiling garages
#46
JNeteler
#47
It's all about leverage.
Think of a see-saw . . . if you made one arm longer and longer it would require less and less weight to lift the other end.
As the lift is raised there is more and more load placed on the outside bolts holding the post in place.
#49
exactly. Think of it this way...with the car 4" off the ground the weight is more evenly distributed across all 5 of the bolts in the concrete. As you move the car up the lift the loads change. And sure, you have two vertical posts but that doesn't mean that as the car moves up the lift the load equalizes across all 5 bolts. The higher up the car goes the more that thing wants to pull itself out of the concrete.
Go find a relatively small tree outside that's 6 feet tall or so. Sturdy enough that you could attach a platform a few inches off the base and stand on it. The tree ain't gonna move much there - but as you keep moving it up eventually the tree is going to fall over because it can't support your weight the same higher up. It's the same principle with the maxjax. Just because there's 2 of them doesn't mean that the outside bolts aren't getting yanked on harder.
You could certainly test that theory with just one maxjax stand alone. You could leave it standing up with no bolts and raise the lift a few inches off the ground and stand on it. It's probably not going to fall over (well, it probably would with a 200lb adult...but if you found someone who equalized the weight instead...). While your standing on it - keep the lift moving up and see what happens...
#50
Never mind... I got it now. The height increases the moment arm about the pivot point (base plate).
I had confused myself by over thinking. (That's my story and I'm sticking to it).![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
JNeteler
JNeteler
#51
Hi,
I got myself such a MaxJax lift and I'm all exited about it. Perfect for my low ceiling garage. Works great, very stable, and very good service from the company. Highly recommended.
Theo
Theo
#52
Professor of Pending Projects
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
See my previous post in this thread... I was afraid to raise the 964 first... lol. So I started with the bike and then the 996TT... last test was with the 964, lol.
Outside of making sure that the bolts are tight and checking again once you have lifted and lowered a car (to make sure everything is seated correctly), there is nothing to it.
Also, it is great to be able to remove the two posts and store them out of the way when not in use.
![](http://forums.rennlist.com/upload/dsc05178_medium.jpg)
#55
ok, I tell my story... I put the lift in myself.
Drilling the concrete was fine until at one bolt I hit iron in the concrete and had to use a dremel to get that out of the way. 2 hours later the drill went in fine. The floor was not very flat so I had to adjust with shims that were supplied and add a little extra myself.
When the lift was ready I raised the car 5 cm and kept it there for a few hours. Lowered it and checked the bolts again. The anchors had moved a litte to settle, which is ok per design. I did this a few times until they were firmly seated.
And when I was absolutely sure there was no more movement I started to wiggle the car on the lift. Just a bit above ground. So nothing dramatic can happen. All ok. Very VERY stable lift I must say.
Next was an endurance test. I lifted the car about 10 cm (wheels) above floor level and kept it there for 15 mins, 1 hour, 1 day, 3 days. Lifted again and again. Perfect every bit of the way. Next phase is a bit higher, 30cm. And so on.
I'm now 99.9% comfortable that it is very stable and reliably fixed. I lift it even at its max height in my garage (not full as the ceiling is too low, even for my low height 928) and work a little underneath. I am still aiming for those last 0.1% and keeping the car on the lift some more time just to make sure it holds. There is no way to see what reserve the floor mounting has, other than to wiggle the car and keep the load on. Every test was performed with outstanding results. Even with a 1650 kg 928gts on it.
This lift is just outstanding and the best that you can buy if tyou want a two-post lift and have low ceiling. I considered every other option and am happy that this is what I bought.
Ok, you need pictures., I understand.
#56
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
Very cool! ![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Ok, you need pictures., I understand.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
#57
Now you guys know how behind I am on reading the threads... Jan 22, 2010!!!
Sorry to revive such an old thread.. my mistake... I read 2011 not 2010... in the words of a famous philosopher, DUH!!
#58
