964 Forum 1989-1994
Flywheel Specifications Needed
Old Nov 12, 2008 | 04:43 PM
jmattiko's Avatar
jmattiko
Default Flywheel Specifications Needed
Hello,
My machine shop has removed an unmeasured amount of material from the friction surface of my flywheel without first measuring the distance between this surface and the pressure plate mating surface. Naturally this distance needs to be maintained to ensure my overall clutch hieght (and subsiuquetnly clamping force) does not change.
Does anybody know what this dimmension should be?
The flywheel is the light weight RS unit... the presure plate is your standard Sachs unit.
Thanks,
Joe.
File Type: jpg
Old Nov 12, 2008 | 04:44 PM
jmattiko's Avatar
jmattiko
Default Flywheel Question - 1990 964
PS> car is a 90' C4
Joe.
