964 Forum 1989-1994
How do I get this out???
Old Nov 7, 2008 | 02:04 PM
Jonnygo1's Avatar
Jonnygo1
Default How do I get this out???
I don't see a place for radio removal tools to go and there is no trim piece to remove.
File Type: jpg
Old Nov 7, 2008 | 02:36 PM
Chimera's Avatar
Chimera
There may be "catches" on the sides, but it should just slide out.
Edit: My unit is aftermarket, not original. Kindly disregard my response.
Doc
RSGulp's Avatar
RSGulp
The end-caps of the stereo fascia clip off (the two thin black plastic covers at the extreme left and right of the unit). Very carefully prise them off with a flat blade.
After you remove the caps you should see the holes where your head unit removal tools go.
More information here:
http://forums.pelicanparts.com/showt...threadid=89315
Old Nov 7, 2008 | 06:12 PM
elbeee964's Avatar
elbeee964
Wink
man points:
Old Nov 7, 2008 | 06:40 PM
paa502's Avatar
paa502
How about tips or experience with removing that piece of the dash "center dash trim" (around CCU/radio/switches)? Pretty sure I can get the lower dash out and the CCU and radio. Would very much like to replace my damaged dash piece with a pristine one.
Thanks!
Old Nov 7, 2008 | 07:19 PM
Ritter v4.0's Avatar
Ritter v4.0
Persuaders
File Type: jpg
Old Nov 7, 2008 | 07:37 PM
elbeee964's Avatar
elbeee964
How about tips or experience with removing that piece of the dash...
Sorry, no tips -- haven't been there. Exploded view, though, I can do.
89 dash:
90 & on:
Old Nov 7, 2008 | 07:47 PM
deep_uv's Avatar
deep_uv
RIP
Originally Posted by elbeee964
man points:
LMAO, you are a riot, Lonnie!
Old Nov 7, 2008 | 07:55 PM
deep_uv's Avatar
deep_uv
RIP
Rich is right.
Here ya go Jonny....
File Type: jpg
Old Nov 7, 2008 | 10:09 PM
dutchcrunch's Avatar
dutchcrunch
Default removal
if concerned about scratching get some 2 inch duct tape/or something real sticky and cot a bout 5 inches long, use a credit car and apply the tap on the sides between the radio and sides of dash, and and rub it real good to make it stick , then pull rapidly, not like a monster and it will come off without marking anything.
Old Nov 8, 2008 | 02:29 AM
pete000's Avatar
pete000
It's a 90's tape deck don't worry about scratching it, just toss into the trash upon removal...Zero value !
IMHO
Old Nov 8, 2008 | 02:36 AM
Oracle's Avatar
Oracle
Does anyone know if the new Blaupunkts are just a drop in (straight swap with old one)? (cause they have the same connections in the frame?)
