964 Forum 1989-1994
Screen washers
Old Oct 16, 2008 | 05:33 PM
Uber 911's Avatar
Uber 911
Registered User
Default Screen washers
This is weird, screen washers work fine, however the screen wash reservoir in the trunk piddles out water(a lot of it) and the screen wash is mixed with water?
Old Oct 17, 2008 | 04:48 AM
Harry Apps's Avatar
Harry Apps
Sounds as though you have a non-return valve stuck open allowing the pressurised (or gravity fed) fluid to travel back into the small reservoir. Look to see where the ball valve is that separates the two pipe runs.
H
Old Oct 17, 2008 | 05:19 AM
Uber 911's Avatar
Uber 911
Registered User
thanks harry..
Old Oct 17, 2008 | 01:11 PM
warmfuzzies's Avatar
warmfuzzies
Then take out the one way valves, and remove the intensive washer tank, it does little and is a complete waste of space..
Or if you're going all RS'y take out the main tank and use the intensive as the main was as it weighs less.
Kevin
Old Oct 17, 2008 | 01:48 PM
Uber 911's Avatar
Uber 911
Registered User
Fixed it, stuffed a one way valve off the intensive washer tank. As a system it is a little 'over engineered' just to squirt a bit of water!
Old Mar 9, 2009 | 10:55 AM
adamfogerty's Avatar
adamfogerty
Hi,
I have just reached the same diagnosis - That I have a one-way valve stuck in the open position.
According to the PET, there are four of the things - Can you point me in the right direction as to where they are physically located?!? It's impossibly to see/get at anything behind the dash...
Thanks in advance,
Adam
Old Mar 9, 2009 | 11:02 AM
Uber 911's Avatar
Uber 911
Registered User
Adam, I left all the valves and plumbing in place, like you said impossible to get at, and put a £2 one way valve on the concentrate screen wash tank. I assume you have the same problem I had; screen washers work fine however, open the 'hood' and a stream fires out of the concentrate tank vent.
chris
