Wheel Spacer question
If I recall correctly, factory Cup 1 on the Turbo is 17 x 7 ET55. Perhaps there are other variations out there which I am not familiar with. Since I am not a Porsche historian, I will let others chime in to confirm.
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
Agent Orange
The factory Cup I is 17x7et55. There are Cup I replica wheels that are 17x7.5et52. Check again if you're seeing a 5 or a 6 there. I don't think there are ANY front Porsche wheels with offsets in the 60mm range.
Not sure how to quote, but here is a pasted excerpt from a post on a prior thread.....
here is a list of oem fitments
Wheel description Part number Size Offset (mm)
design 90, Cast aluminium
964 362 114 01 6JX16 55
964 362 112 01 7JX16 52.3
964 362 116 01 8JX16 52.3
928 362 118 02 9JX16 52.3
Cup design92, Forged aluminium aka Cup1
944 362 112 00 6JX16 52
944 362 113 00 6JX16 52.3
944 362 113 01 6JX16 52.3
944 362 116 00 8JX16 52
928 362 117 00 8JX16 52.3
928 362 117 01 8JX16 52.3
965 362 124 00 7JX17 55
965 362 124 01 7JX17 55
965 362 124 15 7.5JX17 55 needs spacers
965 362 124 05 7.5JX17 65 needs spacers
965 362 126 00 8JX17 52
965 362 126 01 8JX17 52
965 362 128 00 9JX17 55
965 362 128 10 9JX17 55
965 362 128 05 9.5JX17 68 needs spacers
Cup design 93
993 362 124 00 7JX17 55
993 362 124 05 7J.5X17 65 needs spacers
993 362 126 00 8JX17 52
993 362 128 00 9JX17 55
Bill Verburg
Cup design 93
Bill Verburg
965.362.124.05 is a Cup 92 wheel for the front of a 968 and 993.362.124.05 is a Cup 93 wheel, I suspect for the same car.
As I mentioned before, an ET65 wheel will need a 10mm spacer to fit on the front of a 964 as is mentioned in Adrian's book (although he doesn't give the size).
Regards
Dave
