For Sale: New KW Clubsports for 964
Brand new never used set of KW Clubsports for sale for $2790.00 and will ship free in the US. They fit '90 to '94 964 C2.
Ordered them from KW in Germany and paid $3200.00, not including shipping. Selling because the opportunity arose, before I installed the KWs, to buy a friends Moton Motorsport dampers he removed from his car.
They are 2-way adjustable, twin tube damping, independent bump and rebound adjustments with linear race springs. For comparison, springs are 100% firmer in front and 50% firmer in rear than V3 (I was told by KW tech). It comes with the tools to adjust the compression settings, spanner wrench, and instructions on how to install them on your car and adjust the dampers- all in the original new box.
Anyone interested please PM me.
I'm getting questions about fitment for 964 C2 models when searching the KW catalog. For some reason you have to put in "1994" for the year model and it will show the "year ranges" for compatibility. If you put in anything prior to 1994 it only shows fitment products for C4. After you put in 1994 for the year model, it should then show "90 to 94 964 C2" for the Clubsports. These are not compatible with the C4. You must also use your existing factory top-mounts which is why it will work on pre- '92 year models. Hope this helps...
http://www.kw-suspension.com/flexshop/
Had a request for part#s.
The part# listed on the box and in the instructions that came with the kit is #35271711.
Each strut also has a separate signature listed on the housing. The fronts are #7121003 and rears are #7121105. You will find these signatures listed in the PDF file "instructions" for the Clubsports on the KW product finder. It shows they match up with the part# I gave you above. Hope this helps...
