TRG Sway Bar Setup Help
I have a '92 964 and have ordered TRG 25mm front and 22mm rear adjustable sway bars (They are out of 19mm).
I have also installed KW clubsport dual adjustable coilovers. Any experience or recommendations on what position to set the sway bars would be for a good starting point? Front are 5-way adjustable and rear are 3-way.
What to set them at really depends on your car (what spring rates, etc). The usual is to start with middle/middle and adjust as required to get the handling/balance you want for the course you are driving.
That said - I have 25/23 bars on my car with 650/800 lb springs (2100 lb car) and mine are currently set middle/middle but I have had many variations (including rear disconnected) depending on the track and the spring rates I'm running.
Well, turns out they do not fit anyway. The front bar (25mm) does not clear the brake booster. TRG said they have some isolated issues where some cars have either a slightly larger or maybe different mounted booster that could cause a clearance issue. I'll have to look into a different manufacturer, preferrably that has a bend in the middle like the factory.
