964 Forum 1989-1994
5mm wheel spacer question
Old Jul 20, 2008 | 04:18 PM
amr89c4's Avatar
amr89c4
Default 5mm wheel spacer question
I bought some 5mm wheel spacers and new steel lug nuts from Pelican and was assured the studs would be long enough. '89 C4 with Mille Miglia Cups and 205s. I was getting a little rubbing on the back inside fenderwell with the 205s and I had planned on going to 225s and read that the 5mm should alleviate the rubbing. The car had the MMs already on it when I bought it and don't see a receipt for new steering stops.
1) How many threads should be exposed for 'safety'? Seems that full engagement by all the nut threads would be the minimum. I will be DEing the car soon.
2) Neither of the spacers are true flat, with one less flat than the other. Neither are out over a 32nd. Being they are only 5mm and aluminum, I would think they will conform to the hub and the wheel without any issues when torqued up. Do you agree?
Old Jul 20, 2008 | 04:32 PM
carnumber6's Avatar
carnumber6
the studs should at least be flush with the lugnuts to be totally safe .. the spacer will indeed be clamped flat when the wheel is bolted tite..
if your rubbing with just 205's on the rear there is a serious problem with the wheel offset or the alignment ...I have 9 inch rims with 55 offset and 275 section tires on the back with no rubbing.. i
f your talking about the front then make sure you have the updated steering spacer on the rack and you shold be able to run 225 with out a spacer
Old Jul 20, 2008 | 04:41 PM
deep_uv's Avatar
deep_uv
RIP
Yeah, they should coform.
I don't think the threads will be fully engaged with 5mm spacers with the standard studs. They weren't when I tried it. Personally, I wouldn't run spacers for a track application.
I'm really surprised you're rubbing with a 205 up front. Is it rubbing after your suspension change or from before? If it's from no steering stops, that won't be a problem on the track. You'll never turn it that sharp.
Old Jul 20, 2008 | 04:49 PM
amr89c4's Avatar
amr89c4
carnumber6: Alright, I guess I was less than clear. The 205s are on the front. 255s on the rear, no rubbing. The small rub area is on the wall of the left and right front fenderwell, its rubbing the rear of tire vs the front of the tire. I've never heard it and I assume its only at full lock going slow, parking etc.
deepuv: It was rubbing before the suspension change.
I just checked and its obvious the nice fella at Pelican is all wet. I am 3 threads shy of full nut engagement with the 5mm spacer and just flush without it. I really get annoyed when this c#*& happens because I could have easily added longer studs to the order. Now project is delayed again.
Old Jul 20, 2008 | 08:56 PM
DanielT's Avatar
DanielT
hmmmm, carnumber6, I wonder who that could be...?
anyway, this updated steering spacer, does this just not allow the steering rack to turn as far right and left? If so, why not just crank the wheel over as far?
that would be my CSOB solution.
Old Jul 20, 2008 | 09:12 PM
38D's Avatar
38D
All the 964 cups that run Dunlops run a 5mm spacer in the rear. I'm not sure why you think spacers would be an issue.
Old Jul 20, 2008 | 10:26 PM
deep_uv's Avatar
deep_uv
RIP
I meant with the standard studs.
Old Jul 21, 2008 | 12:44 AM
porschapete91's Avatar
porschapete91
Default spacers
Giday Crew,A couple of paragraphs from Adrain's book "Wheel spacers up to and including 6mm (0.24in thick) do not require longer studs to be installed in the wheel hub" and then he go's on to say"The author and others experienced in this issue recommend longer studs be used with spacers thicker than 5mm(about1/4 in). For the race track using 964 owners,longer studs and steel wheel nuts are recommended for all spacers no matter what the thickness" He also states A wheel spacer from 7mm to 40mm(0.275 to 1.574in) requires longer studs to be installed into the hub. from page 276 hope this helps
Old Jul 21, 2008 | 12:26 PM
DogInBlack's Avatar
DogInBlack
Does anyone have any experience with the H&R DRM spacers? http://www.automotion.com/productpage.aspx?pid=102089
I just bought a set of Fikse FM10s 8x17F and 9x17R from Wheel Enhancement with 55mm offsets. I'm running 255/40/17 Michelin Sport Cups on the rear with -2.0 degree camber and am getting a little rub on the control arm when the sidewall is fully flexed on hairpins. Advice?
Old Jul 21, 2008 | 12:56 PM
DanielT's Avatar
DanielT
I have the DRMs on the rear of my C2, using them with Cup II 9x17s and 255x40x17s. Mine are 14mm thick
they work very nicely. Very clean and you don't have to change studs every time you use different wheels.
If you read the information on the H&R website about them, you will find that the wheels you use them with will need to have the back of the mounting flange scalloped so they work correctly. If the wheels you have are flat on the back of the mounting flange the DRMs will not work and you will need to use the normal type spacers with longer wheel studs.
here are a couple of pics
Old Jul 21, 2008 | 01:21 PM
Marc Shaw's Avatar
Marc Shaw
Super Duper Moderator
I use a set of the H&R DRM's (18 mm) with the MY02 18" 5-spoke rims I save for best as the rear offsets are 65.
I would not use spacers like this on the track as you can't easily check the torques of the spacer-to-hub lugs.
Marc
Old Jul 21, 2008 | 09:06 PM
Metal Guru's Avatar
Metal Guru
If you get steering wheel shimmy from the spacers, just rotate one of them 180 degrees from it's original position.
Old Jul 21, 2008 | 10:33 PM
38D's Avatar
38D
I raced this style of spacer/adapters on my C2 turbo for 3 years without issue.
Old Jul 21, 2008 | 10:54 PM
DanielT's Avatar
DanielT
I agree, if you check the torque when you do your pre-event inspection/servicing, there should be no problems with these.
and since you aren't taking them off and on constantly like a wheel, I doubt the torque values would change appreciably if at all from service to service.
Old Jul 22, 2008 | 02:59 AM
pete000's Avatar
pete000
I run 5mm spacers on all four wheels with stock studs. I know they are not quite as long as they should be, I dont track my car.
I have no shimmy.
