Retractable Spoiler Help
The two round connectors on both ends are no brainers, but the two wires with blade connectors are a little confusing. One appears to be a ground (brown) and the other is red/black. Whomever installed the fixed wing must have cut some wires because I cannot determine where to connect these wires. Can someone take a couple photos of their engine bay and demonstrate where these wires connect (on both ends of the harness)? Much appreciated.
Also, how do you remove the retractable spoiler from the actual deck? Does it need to be deployed first? Where are the mounting points? The retractable spoiler I purchased came mounted to a deck and I want to remove it and install it on the deck that is currently on my car. Thanks in advance. Jim
