964 Forum 1989-1994
Let's talk about C4 ride height some more
Old 07-18-2008, 07:04 PM
elbeee964
elbeee964's Avatar
diggin' the blue line-enhanced pics. nearly art.
Old 07-18-2008, 08:19 PM
amr89c4
amr89c4's Avatar
Your car looks great! Since the C2 and C4s share the same front and rear axle alignment specs there should not be any issues setting at RS specs.
I see you used RS ride height +5, but do you have the alignment specs, or do you recall if you used stock or RS specs? I plan to use RS specs as a minimum and may go a little more aggressive on camber, to maybe 1.5
Thanks for sharing the pics and the information.
Old 07-21-2008, 03:57 PM
TH996
TH996's Avatar
I finally found my official height/alignment specs:
Height:
LF/RF: 25 7/8 and 130mm
LR/RR: 25 3/8 and 223mm
Alignment:
Front
Camber: -0.75 left, -0.75 right
Caster: +4.5 left, +4.6 right
Toe in total: 0.06"
Rear:
Camber: -1.0 left, 1.0 right
Toe in total: 0.06"
It think these are less aggressive than RS spec.
Quick Reply: Let's talk about C4 ride height some more
