Yet another Intermittent Ignition Cut off - when hitting bumps
#46
Don't forget the crank positioning sensor. Solved it for me:
https://rennlist.com/forums/964-foru...-the-hook.html
#48
When I hit a bump, the check engine light comes on, and the differential light in the middle dashboard comes on (light is located at J39 of the schematic, 1990 C4, sheet 4).
Scratching my head?.......looks like the differential light goes to the V-belt, then through the DME connector?
