964 Forum 1989-1994
Removing rear bumper!!
Old Jul 16, 2008 | 08:11 AM
biglicks's Avatar
biglicks
Rob,
the aluminium bar is in effect your crash impact piece. The rear plastic bumper will absorb minor dings it's the big metal bar behind that takes the larger ones. Not sure I'd have the confidence to remove it, in the event of a rear shunt it does offer some protection to your engine/exhaust etc.
Steve
Old May 31, 2011 | 06:57 AM
clutch-monkey's Avatar
clutch-monkey
sorry to bump old thread.. following the suggestions here has helped but i'm stuck with removing/disconnecting the wiring for the license plate illuminators. seems to feed through a small hole in the top edge of the bumper?
Old May 31, 2011 | 09:09 AM
Rocket Rob's Avatar
Rocket Rob
IHI KING!
To disconnect the wiring to the license plat lights, you need to remove the right rear tail light. Under it, there is an electrical connector for the license plate lights.
Old May 31, 2011 | 09:41 AM
clutch-monkey
thanks!
Old Jun 1, 2011 | 01:57 AM
clutch-monkey
mission successful thanks to the instructions in this thread, thanks again guys.
Old Jun 1, 2011 | 05:55 AM
KaiB's Avatar
KaiB
Lordy! All those tools on the ground, a hammer, crowbar, lamp, faulty drop cords and torn gaskets...
Looks like the spot beneath my tractor.
Old Jun 1, 2011 | 06:37 AM
clutch-monkey
haha. this is quite good for my garage actually
eg:
