Scantool Climate Control Errors
I have a questions regarding a few climate control errors. I originally had a 15=Rear fan temperature sensor that I ordered a new part and replaced and that cured that error. Then I started to get the following:
41=Condenser blower motor
43=Rear blower motor speed 1
I can clear the codes and they will sooner or later return. I searched and can not find a definate fix. I tested my condenser fan by removing the relay and jumping the fan and it works on both speeds. I also tested the rear fan and it seems to be working correctly. I know there are some codes that should just be ignored. Are these the codes? Any help is appreciated.
Dave
Dave
Did you test your blower using the scantool? The electric motor might work when jumped out, it it doesn't work due to a faulty CCU.
Run scantool again , test outputs for the climate control, specifically activate the following:
11 A/C condenser fan slow
12 A/C fast
13 Oil cooler fan speed low
14 Oil cooler fan speed high
15 stage 1 of rear blower (slow)
16 stage 2 rear blower (fast)
If these test all right, then review the TSB.
Now a member has TSB's in PDF on his website, but I can't find the link. There is a list of error codes and fixes. I'll get back w/ the URL, I was just there a few days ago.....
12 A/C fast
12 A/C fast
12 A/C fast
