RS Sway Bars - What settings are you running?
What front and rear setting settings are you running on your RS sways? I know this is a bit subjective, but I am just curious what other people like. My car has JIC coilovers and I run R comp tires most of the time.
Thanks for your input.
I have RS sways on my 993 daily driver (with PSS9's). I use middle in front and firm in the rear. I have not changed since I used these settings for track and autox before buying the Turtle.
Basic Site Sponsor
Basic Site Sponsor
You can't gauge off of what others run. Your spring rates, shock valving, camber and tire combination will all affect your car balance, and thus your sway bar settings.
That being said, I run mine one from full soft in the front and full stiff in the back.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
I'm at full soft front and full stiff rear.
Location: WhippetWorld, .........is it really only this many
1 Post
Currently at middle rear, 2nd soft at front but now going full soft front full hard rear.
Which sort of begs the question whats the point of it being adjustable given the previous replies
Basic Site Sponsor
Basic Site Sponsor
Sway bars allow you to make gross adjustments in the balance of the car. If the car has a predominant tendency toward oversteer or understeer, you can change the springs and/or adjust the sway bars to bring the car back into balance. Once you have the general balance close, you can adjust the shocks (if you have that type) to further tune the balance of the car in the 3 parts of the corner.
I have the TRG 25/22's set one setting stiffer from the middle at the front and full soft at the rear.
Josh, I think we need to do some mod's on your car (it's only money). Just take a look at Tom W's ride, that is SWEET!
Leave your front right where it is at and stiffen the rear one more notch, then you will be one off the stiffest setting.
What tire pressure were you ending up with hot?
That will be an easy adjustment and create better turn-in or rear control (greasy feeling).
I have just installed the front 5 way adjustable sway bar on my 91 C2. It appears I can only use the back 3 adjustment holes. The 2 closest to the A arm are unusable as the knuckle of the RS drop link interferes there. Have I done something wrong?
Basic Site Sponsor
Basic Site Sponsor
I sold my RSA 2 & 1/2 years ago, but if I remember correctly the bend on the drop links goes at the bottom, and they curve so that they clear the A arm.
