964 Forum 1989-1994
3 signs you need a top end rebuild
Old 06-18-2008, 06:31 PM
1991 porsche carrera 2
1991 porsche carrera 2's Avatar
Default 3 signs you need a top end rebuild
Could someone please post the three most common signs that you would need a top end rebuild. such as, buning excessive oil, loss of power and so on. Thanks Mike
Old 06-18-2008, 07:19 PM
Henry964
Henry964's Avatar
I would like to know too
Old 06-18-2008, 07:45 PM
Indycam
Indycam's Avatar
#1 , Bad leak down results .
Old 06-18-2008, 07:56 PM
boxsey911
boxsey911's Avatar
#4 You have the money to spare so decide you're going to get it done anwyay
Old 06-18-2008, 08:51 PM
MisterRisky
MisterRisky's Avatar
specifically, leak down results showing that your valves are leaking.
also, oil leaks that require pulling the heads... 'cause "while you are in there..."
Bearclaw
Bearclaw's Avatar
Location: Seattle xburb - I can't see the Emerald City, but I know it's out there somewhere
#1(a): You're trying to sell your car, and buyers keep telling you, "With those miles, it's gonna need the top end done pretty soon." ???
Old 06-18-2008, 09:18 PM
joey bagadonuts
joey bagadonuts's Avatar
#2 , See reason #1
You could probably confirm via a dyno but that's just more money. Leak down would be fairly definitive.
Old 06-18-2008, 11:14 PM
elbeee964
elbeee964's Avatar
(...everyone's a Letterman w/ that question)
Old 06-19-2008, 01:42 AM
gfunk
gfunk's Avatar
If the valve guides are worn you can have decent leak down results but still need a rebuild.
Old 06-19-2008, 06:25 AM
darth
darth's Avatar
Without getting into compression/leakdown tests:
Even after a valve adjust you still hear the tickity tick and/or while driving on deceleration then reapplying throttle you see a puff of blue smoke ( also on start up) - indicating worn valve guides. An easy check is to look at the spark plugs they should be dry and tan in color not wet oily black.
Hard starting - which may indicate leaky or burnt valves not creating a perfect seal and in turn creating an imperfect combustion charge.
Hope this helps
Bill
90C2
Old 06-19-2008, 08:33 AM
Crystal Cranks
Crystal Cranks's Avatar
#7(c) Your wife finds that stash of cash you are keeping for upgrades and mods but you explain its actually for a very necesssary rebuild.
Old 06-19-2008, 01:28 PM
Ritter v4.0
Ritter v4.0's Avatar
Your mechanic's kids need their teeth straightened.
Old 06-19-2008, 02:55 PM
elbeee964
elbeee964's Avatar
It's summer, and your neighborhood is mosquito-free for the first time in years...
Old 06-19-2008, 03:56 PM
MisterRisky
Lonnie is right on. Below is the 1950's era visualization:
Thanks to the Hawaiian Department of Heath and Google Image Search
Old 06-19-2008, 03:59 PM
ilko
Agent Orange
ilko's Avatar
You read Rennlist too much and think every sound out of the ordinary is your valves walking away from you.
Quick Reply: 3 signs you need a top end rebuild
