Extreme Problem urgent help request
I am based in North London
Thanks for the kind words, will try to remain calm!
Regards
JZ Machtech are near Watford and are very good :
http://www.jzmachtech.com/shells/
Incidentally - where did you get the car? Was it a private sale? What does the seller say?
Basic Site Sponsor
Basic Site Sponsor
Like Christer says, never panic, but it would appear then that the self-diagnoses stage is over. I agree that a competent mechanic should have a look at it. Tell him exactly what happened, but don't, DON'T under any circumstances advance your own theory as to what you think is wrong. Let him check it out with no pre-conceived ideas.
BTW a leak down is a pressurization of each cylinder to see how much pressure the cylinder can hold. It tests the sealing of the valves and rings at Top Dead Center (firing position). Using a constant 100 psi source, if the cylinder can hold 97 psi, then you have 3% leak down, which is good. Over 10% is getting weak, and over 20% is time for a re-build.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
Hi Dave,
Private sale unfortunately, cnn't be bothered with the seller who had made me sign a final sale/ no warranty receipt And lied big time!!
Thanks for the info- have booked a flatbed to take cat to specialist, wait and see- fingers crossed!
POKERINO
Totally agree with you, having the car put on flatbed truck for someone to have a look at- being taken away this afternoon. As mentioned, my biggest worry now is to either have it fixed before the move company takes it away, or at lease order all the parts before shipping and then take the time to build myself once in Australia. The part you explained with the leakdown is brilliant! would this also tell us if the oil is then leaking into the camshaft? if so at least we will know where to start.
I really love this car (honestly and would do my best to make it roadworthy) unfortunately resources are limited at the moment and have to keep a close eye on the final bill.
POKERINO
Porker
Reading your posts is like trying to track a fly with your eyes in the air after drinking 12 pints of vodka - I am getting dizzy.
Let me say it again:
Calm down. Let the experts take a look. Listen to what they have to say. Did I mention 'calm down'? You are already considering many things that may not even be relevant. I can vouch for the fact that JZ Machtech are not the cheapest in terms of basic 'per-hour' labour rates, but are usually very good at not spending more time than they have to in diagnosing problems - so its a good choice. They also have an excellent reputation.
Let us know what they say when you hear something. At this stage, it is simply not worth it to get too far ahead of yourself!
Checking oil level on a 964 is different than any other car that I've ever had. The engine must be at operating temperature. That would take about 20 minutes of relatively hard driving to get it there. It's the only car I've had where the oil level is checked while the engine's running. You have an oil level guage and an oil temperature guage. For the 964's I've had, a good rule is to have the oil temperature and oil level guages equal. That means, if the oil temperature needle is 1/4 up the guage, the oil level needle should be there also (of course, that's after the car is warmed and has idled for 30 seconds on level ground).
Another rule is if the the oil is leaking on the right hand side of the car, high oil level or sloppy oil changing that has spilled oil is the 1st place to look. Getting oil into a 964 w/o spilling takes some practice. You will become painfully aware of this when you change your own oil for the 1st time.
You've gotten great advice. have it checked out and let us know. My $$ is on an overfilled oil system.
These words are a welcome relief as are the previous posters. You all have been very supportive. Lets wait and see......
Professor of Pending Projects
and the time I thought my car had no oil pressure and it was because I was looking at the wrong gauge... the sad part is that those to events were some 5 years apart ... just a blonde moment I guess... it takes time getting use to these cars.
Anyway, here to hoping it was just an oil overfill issue
I know quite a few people have exported cars to Australia on here and i vaguely remember that the the checks on the car and the requirements are quite rigid in regard to OEM equipment.
Maybe time for a few detail checks.
I'm sorry if this adds to your woes.
Even the local indy air-cooled guru overfilled mine on its first oil change.
After that, I started changing my own oil, just like the rest of my vehicles.
