Rear tail light removal and rubber seal replacement
I did a search before, but did not see anything. It is very obvious that water seeps into the left (driver) side tail light when washing the car. It looks like the rubber seal need to be replaced. Is the single screw on the side of the light the only thing that hold the tail light? Does replacing the rubber seal around the light require any special tools or skills?
TIA
TIA
The rubber seal has nothing to do with water seeping into the tail light. The tail light is a sealed unit and the rubber seal is only used between the tail light and the body. My guess is that the lens has come loose (or may have cracked) from the rest of the tail light housing.
Is the single screw on the side of the light the only thing that hold the tail light? TIA
FWIW, And behind the driver's side tail light, in it's alcove, you may find an engine bay emergency hood release lanyard.
Some cars came with it. For instance, mine didn't, so I made one. It's similar to your front hood's emergency release.
