URGENT HELP NEEDED: Must disable alarm
I'm at a club race which starts tomorrow. My car quit halfway through a turn and now will not start. My alarm unit filled with water and corroded. I cannot get another one, I don't need one since it is a race car and I need to know how to get this motor running again or else I'm screwed.
If you are afraid to tell over a public forum then please PM me.
Thanks for your help
Azzy
Azzy
Your alarm control unit is not allowing your DME relay to provide power to the fuel pump. Pull the DME relay and jumper together positions 30, 87 and 87b. That will be pins 3, 5 and 7 on the car side. Of course, check your wiring diagram to be sure.
Thanks folks. Sorry I didn't reply sooner - racing has a way of keeping you busy. Found out that it was a bad wire from my kill switch to the fuel pump. replaced that (thanks to Larry Herman) and was on my way and won the race.
