Cigarette lighter fixing
Seems like my car had a new one fitted at some stage, but not to the electrical connection!!!!!, I pulled the lighter out and the whole lot came out, how should it be held in place,I need it for my sat nav.
Its got a part no. on the inner body part 964.652.319.00 and has a black crackly finish on the edge lip.
There should be a connector nearly behind it that has the shape of an inverted T for the connectors. It has a small light bulb on it that lights up the "hole" so you can get the lighter back in at night...
You will want to pull your radio to get your hand in there to make the connection. Don't waste a perfectly good hour trying without doing that... (btdt.)
