RUF RCT Evo info & photos needed
I am searching for information on the 964-based RUF RCT and RCT Evo models (380hp & 425hp).
Does anyone have detailed photos of the engine bay with the intercooler removed and photos under the car showing the turbo, exhaust and intercooler plumbing?
I am curious how RUF routed the turbo system plumbing while retaining the stock 964 airbox and the heater boxes.
Regarding the engine, RUF's tech sheet says "Engine gets special
cylinder heads, pistons, and camshafts." and it lists the C/R at 9.0:1. It makes no mention of changing the cylinders so I have to assume that the stock 964 cylinders are retained.
Can anyone confirm if the original 964 Bosch air flow meter was retained or did RUF upgrade the car with a MAF? What boost pressure did the RCT Evo run.
