Wiring the temp sensor to OBD
Hi, I have previously fitted an OBD to my 1990 C4 and being **** now want to attach the temp sensor.
The original elephant ear mirrors have previously been replaced with teardrop ones, so any wiring originally present is now gone.
Sooooo does anyone know how to wire the sensor into the loom? My mechanic will be doing the work and I don't want to pay him to investigate how to do it (he has indicated he'll have to do this).
Many thanks for any info supplied.
Cheers
Gordon
Cheers
Gordon
OBD, temp sensor, mirrors....
Are there a typo in there? are you really talking about OBC?
if so, please take a look at http://p-car.com/diy/obc/ if you haven't already...
I did the retro-fit on my car.. and I didn't go to the wiring under the seat. I simply ran it through the door, (careful to keep it inside the rubber door connector)and behind the dash. I then spliced into the #8 and #10 connectors at the back of the tach connector. (double check those numbers, before you do this)... and it works like a charm. It is a simpler wiring job.
