Anyone replaced their flywheel speed sensor????
Long time and all that, but having just done this job, my advice is to (carefully) cut and break the bracket. It's way cheaper than the sensor. If you cut the bracket in a couple of places, you may avoid any damage to the sensor body.
Steel + aluminium alloy = corrosion.
Take steps to reduce this happening to the new bracket. Given the proximity to the exhaust, I put a bit of brake assembly grease in there.
