964 Forum 1989-1994
lug nut impossible to unattach from bolt
Old Mar 15, 2008 | 02:10 PM
Henry964's Avatar
Henry964
Default lug nut impossible to unattach from bolt
Today I went to a Tire repair shop because I have a small nail in the front driver side tire.
One of the nuts was too strongly attached to the bolt and so I asked them to stop trying for fear of breaking the bolt.
Is there a way to solve this without breaking the bolt? and subsequently changing the wheel bolt.
Old Mar 15, 2008 | 02:44 PM
38D's Avatar
38D
If they break the wheel stud it can be replaced quite easily
Old Mar 15, 2008 | 03:04 PM
kimo964's Avatar
kimo964
I've replaced a wheel stud before, not a big deal. I can't imagine a lug so tight that it can't be loosen with a breaker bar. GL
Old Mar 15, 2008 | 03:08 PM
chris walrod's Avatar
chris walrod
Guru
Rennlist Small
Business Sponsor
Did the nut start to loosen then seize?
Old Mar 15, 2008 | 03:10 PM
Henry964's Avatar
Henry964
Thanks!!!
I will take my car to the official service and see what happens, maybe they can take the wheel out without breaking anything
Old Mar 16, 2008 | 01:37 PM
springer3's Avatar
springer3
A little heat sometimes works miracles, but I have never had a problem with a wheel nut and don't have any experience with that connection.
Alumium thermal expansion is almost double that of steel, so an aluminum nut on a steel stud should loosen with heat. Watch out - aluminum should never be heated above the temperature of boiling water. If a water droplet sizzles even a little, you have it too hot and the aluminum nut will start to anneal (soften and weaken permanently). With steel you are safe until you see a dull red glow, and then you are just a little too hot. It takes time to do the damage, so as long as you are careful, and back off on the heat quickly, you will do no harm.
