964 Forum 1989-1994
4 or 5mm spacers on fronts of 964?
Old 03-14-2008, 01:57 AM
kgorman
kgorman's Avatar
Ron, be safe, just do it yourself.
https://rennlist.com/forums/showthre...highlight=stud
Old 03-14-2008, 12:38 PM
Marc Shaw
Super Duper Moderator
Marc Shaw's Avatar
Originally Posted by kgorman
It is easy to swap out studs - an hour or less for front and the same for rear.
The studs are (reasonable) cheap and no special tools are needed.
I have a 9 mm spacer in the rear with 57mm spacers and 4 mm spacers from with 52 mm spacers (stock are 45 mm). There were added d/t tire rub, not cosmetics.
The safest thing to do it not generatize but just buy an open top steel lug nut and install the spacer and wheel then screw the lug nut on to see how much thread is captured and mae sure it is enough.
Marc
Old 03-15-2008, 09:39 AM
cobalt
cobalt's Avatar
Received 2,080 Likes on 1,251 Posts
I tried different spacers and the only ones I felt safe with in the front is 3mm. There wasn't enough hub for the wheel to center on if I went more than 3mm. If you don't mind allowing your studs to support the wheel you can use larger but I wouldn't. I replaced all my studs with longer ones. I highly recommend it and an easy cheap upgrade. I use the 3 mm spacer up front with the 7 x17" cup 1 and a 235 Toyo RA1 for AX and a 15mm bolt on spacer with hub and 9 x17" 275 RA 1 rear. It is more than enough with the larger tire to work. I know the 235 on a 7 is not recommended but this is the same setup Toyo used for the Toyo cup series.
For track use I use the 18"s and these are setup for maximum offset so I don't use any spacers.
Old 03-16-2008, 11:37 PM
ilko
Agent Orange
ilko's Avatar
Took a few pics this weekend. Here's the 4mm spacer on my front wheel:
Old 03-17-2008, 09:03 AM
RonCT
Moderator
RonCT's Avatar
Thanks for posting the photo. Looks like enough centering remaining, maybe even enough for a 5mm. I'll have to get my car home to see how much thread I have available and work from there given the BBS wheels.
Old 03-17-2008, 11:17 AM
Ag02M5
Ag02M5's Avatar
I'd like to buy a set of 4-5mm spacers (4) if anyone has some they aren't using.
Cheers.
RT
Old 12-02-2010, 02:36 PM
zero9nine
zero9nine's Avatar
Originally Posted by pete000
I am running 7mm on all four wheels. Works perfectly.
Pete,
Did you change the studs to run the 7mm spacers?
Got any pics of the stance? Is your car lowered?
John
Old 12-02-2010, 03:41 PM
Busta Rib
Busta Rib's Avatar
Received 1,102 Likes on 412 Posts
I ran 5mm spacers up front on my widebody C4 with no problems using 3.6 Speedlines.
Old 12-02-2010, 06:24 PM
pete000
pete000's Avatar
Originally Posted by zero9nine
Pete,
John
Stock studs, Wheel Enhancement say's no need to change them up to 7mm.
My car is lowered running )E Cup 1's 7's up front and 9's on rear.
Old 12-03-2010, 09:41 AM
cobalt
cobalt's Avatar
Are your spacers hub centering? if not the centering ring on the hub is exactly 7 mm and you will loose the added support needed under hard cornering. All the load is placed on the studs which I would caution doing.
Also 7mm is pushing it without longer studs. An open lug bolt will leave several threads exposed which I would not feel safe doing. I recommend counting the number of turns the lug nuts have with thee spacers vs without.
Old 12-03-2010, 02:23 PM
pete000
pete000's Avatar
Just double checked my spacers, they are OE 5mm. They work fine with out longer studs and maintain Hub centric.
Sorry for the confusion.
Old 12-03-2010, 10:15 PM
cobalt
cobalt's Avatar
Quick Reply: 4 or 5mm spacers on fronts of 964?
