Clutch pedal adjustment
Having an issue on my C2 that feels like a clutch adjustment issue. The pedal is inconsistent. Sometimes you push it down and its perfectly fine, other times it does not completely disengage the clutch and wont return back to the top on its own. On other cars I have owned, the was fixed with a pedal adjustment, however I do not see an obvious spot to make the adjustment.
So, would you guys agree with this, and if so, is there a way to adjust it?
I agree that you should bleed your clutch slave cylinder 1st. The workshop manual refers to a boost spring in the pedal cluster that can be adjusted by rotating the hex socket head bolt. The clearance between the screw and pivot should be 6MM.
Great stuff guys. Thanks
I already have the Motiv power bleeder from my previous car and have Motul fluid I have been meaning to replace the brake fluid with on a full flush. May as well do the clutch fluid well i am at it
