Which Turn Signal Assembly?
Doing some things to my dash the other day and I came across an unused connector tucked into the steering column. Nothing unusual in these cars, I find connectors like this all the time, but I was curious. A bit of research shows it to be a "Automatic SPeed Control" system aka Cruise Control. Get to thinking that the throttle body has two cables going to it - maybe one is for Cruise Control? Maybe my car has it installed and it's never been used all these years?
Turns out my car does indeed have cruise control (option code 454) but apparently Hans installed the wrong turn signal assembly that doesn't have a cruise control switch in it (or a PO replaced it with the wrong assembly).
I haven't removed the assembly - yet. But looking in the PET I would assume it is part no. 928 613 308, the only one that doesn't list option 454. My query is which one of the three others could be the proper one as they all list option 454.
928 613 304/305/313 (and what is a 928 part doing in my car!)
Another question is would a 944 or 964 assembly fit? I see lots of them for sale on ebay plus they're also available from Pelican as a stock item.
The option codes are:
M130 - English Lettering
M288 - Headlamp Washer
M454 - Speed Control
M562 - Airbag
M659 - Computer
Be glad that the same parts were used for several different models. Keeps the price at merely expensive instead of truly outrageous.
Regards,
JNeteler
M562 - Airbag
M659 - Computer
Regards,
JNeteler
