1993 C4 overhaul underway, suggestions wanted
Got a few bucks to blow on my stock C4.... going for the RSA look
So far Ive ordered....
Bilstein HD's all around
RSA wing
Tech Art splitter
Steve Wong Chip
Aluminum interior bits (shifter, instrument rings, etc)
Clear corners
17" wheels to be painted black (matching the car - I like the look)
Any other must-haves before I take her in for the work?
I want a killer look with a little more performance... planning a liitle track time at mid ohio this summer
ideas welcome...
RSA wing
Tech Art splitter
Steve Wong Chip
Clear corners
ideas welcome...
For the track, you'll probably want the brakes serviced (if it's not something you do on your own). Flush the system with DOT 4 brake fluid and install race pads. You'll overcook things pretty quickly with street pads.
More track-related/durability suggestions:
Alignment/corner balance
Transmission lube
Good tires (r compounds?)
Oil/filter change
Wipers
Rollbar/cage
Race buckets
Harnesses
Have fun and be safe!
Transmission lube
Oil/filter change
Wipers
Rollbar/cage
Race buckets
Harnesses
