RS Club Sport Wheel and horn issue
Well, to get my hands in the dash to install the new antenna booster i needed to get all the dials out which meant taking the steering wheel off. Now i can't remember how it came off and the horn is constantly on or the fittings don't go together correctly.
Can anyone post some pictures or talk me through the installation and i'll start from scratch.
** I did take some pictures as i took it off but the SD card seems to be faulty.
Steve I posted these instruction on the PCGB forum about fitting a clubsport wheel a while ago. They are more than you need but you might twig something that you're missing from them;
1. Make sure the front wheels are straight
2. Remove old wheel (and old boss) and remove the big nut and washer (probably best to mark the nut first before undoing).
3. Fit new boss onto spline making sure two of the bolt holes on the boss are horizontal (I think this is the correct orientation).
4. Fit washer and nut and tighten to original position.
5. Feed on the boss's rubber gaiter.
6. Attach the new wheel to the boss (3 allen bolts)
7. Attach the two wires that are on the boss to the spade connectors on the horn button.
8. Put on the big spring, compress it and secure it using the 3 silver screws and plastic washers.
9. Clip on the horn pad.
10. At point 6 above you might need to take the boss off again and move it one or two splines, right or left as appropriate.
