Tip shift hiccup
Hi All:
Just bought a stock 90 C2 964. Very clean and well taken care of.
I've noticed a strange hiccup that seems to occur regularly under certain situations.
A strange hesitation occurs right after shifting in to 2nd in M mode. Right after the shift from 1st, and when I'm right over 3000 RPMs there is a momentary power dip as if I've taken my foot off the gas.
It almost feels as the car wants to shift into 3rd prematurely or as if the car has a 2.5 gear (if that makes any sense). Its only a blip, but causes the tach to drop about 200-300 rpm during this point. Obviously with continued application of throttle it recovers within a second.
Is this a known characteristic of these era Tips?
I had a similar hesitation which was solved by replacing the coils.
Try unplugging the igniters one at a time and see if the car still starts and runs smoothly on each coil independently. This is a fair first test on the coils.
The following thread has pics: What effect to coils have on power?
Burgled
getting a 1/2 gear feeling at that shift point is normal.
Search its been discussed many times and welcome. Usually the first post has pictures of your car
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
