964 Forum 1989-1994
Clutch master cylinder leaking
Old 01-18-2008, 02:06 PM
Southampton76
Southampton76's Avatar
Default Clutch master cylinder leaking
Found a large damp patch of blue brake fluid in the floor pan this morning while trying to install a rennline track mat.
I had strange clutch problems in the summer, slipping, tough to engage 1st gear and I now suspect the master is leaking and could be causing the clutch problems.
Anyone confirm that a bad master could lead to slipping and shifting problems..has anyone had them and found a new master and slave and bleed fixed the clutch problems?
Seems like an easy switch out, anyone offer any advise?
Cheers
Mark
Old 01-18-2008, 02:12 PM
Indycam
Indycam's Avatar
I don't think a leaking master could cause slipping .
Old 01-18-2008, 02:21 PM
garrett376
garrett376's Avatar
It looks like an easy job but I found it to be a knuckle buster!!
If your clutch slips, usually that means it is worn out. If you have trouble engaging gears, that can be a hydraulic issue.
Old 01-18-2008, 02:25 PM
Southampton76
I have ordered a new master, slave and hose. See if that changes anything with a bleed. They are cheap, so who knows.
Old 01-18-2008, 03:45 PM
DAVISRILEY
DAVISRILEY's Avatar
Slave and line aren't too bad to do, just an all left hand job, so if you are left handed, you have a leg up. I found it was easier to tighten the line to the slave off of the car, and then put the whole thing in as a unit. Don't have any experience with the master, but that's next on the list. Good luck.
Quick Reply: Clutch master cylinder leaking
