Brake pad question ?
Hi,
I have a UK 1991 c2 Tip standard brakes..........are the front and rear pads the same or different.........any pics would be welcome
Steve
Steve
Steve, assuming you have standard brakes then you have the small 2 pot calipers on the back. The pads for these are totally different to the front pads. Here's what the 2 pot calipers look like and the pads:
![](http://i32.photobucket.com/albums/d25/brksy16/964%20diy/PA271045.jpg)
![](http://i32.photobucket.com/albums/d25/brksy16/964%20diy/PA261045.jpg)
1 Post
Yes, that should be correct. I have a later 964 with the four pot rear calipers and my front and rear pads are interchangeable. Makes it very convenient to move the front pads to the rear when they get below 50% and replace the fronts with new ones.
It had crossed my mind............so to clarify everything
C2 standard has front pads that are the same as C4 front and rear
C2 rear pads are different(small type)
Is it an easy swap fitting C4 calipers to front of C2
STEVE
STEVE
C4 rear calipers will directly fit on a C2. How easy it is to do is dependent on how siezed the brake line couplings are
Rear brake upgrade advice
