964 Forum 1989-1994
Headlight Aim Adjustment
Old Jan 5, 2008 | 02:51 AM
jneteler's Avatar
jneteler
Question Headlight Aim Adjustment
Hi,
Does anyone have a pattern or guideline for adjusting the aim on headlights?
Search did not yield any relevant results.
This is a RHD 91 C4. The aim on mine seems to be totally off. Both seem to aimed somewhat high. The left (passenger side) beam is aimed too far right as well. Its almost as if the lights were aimed after the suspension was lowered at a standard height target by the PO.
I also noticed that both headlight lenses have arrows pointing to left (passenger side). Is this correct for a RHD?
Regards,
JNeteler
Old Jan 5, 2008 | 04:59 AM
Computamedic's Avatar
Computamedic
The UK MOT Test includes a check on headlight aim - details can be found here.
The arrow pointing to the left on the headlight lens is, AFAIK, correct - it indicates a left hand dip (not left hand drive). I'm pretty sure the headlamps in a LHD car will have arrows pointing to the right, i.e. right hand dip.
Hope that helps.
Regards
Dave
Old Jan 5, 2008 | 08:46 AM
jneteler's Avatar
jneteler
Dave,
Thanks for the info!
This should help. I'll make a few measurements and the adjustments.
Regards from the erstwhile colony of Malaya,
JNeteler
