Rear bumper removal
Registered User
Hi guys i have removed my rear bumper..... but the problem is i cant disconnect the stupid liscense plate light wire!!! I see that it connects at a junction inside right rear tail light assembly but it goes through a grommet that i cant get out and the plug wont fit through the grommet. It must also connect somewhere in the bumper, the problem is the wire goes underneath some heat insulation and disappears.
Can you help me??
JERRY
Can you help me??
JERRY
I just removed my bumper last week. All you have to do is push the whole grommet through.... not the wire through the grommet.... it looks like a tight fit but the grommet is very flexible.
Hope that helps!
Hope that helps!
