Top End Rebuild - What did it Cost/
Burgled
details about my rebuild below - with JZ Machtech.
Rebuild costs
Top end overhaul
Head gasket set
Valve guide
Guide inlt
Timing chain
Chain tensioner (L&R)
Tensioner (O/S)
Tensioner (N/S)
Piston ring set
Tensioner S/rail (x2)
Rear crank seal
Front crank seal
o-ring (x2)
return tube
oil filter
Sundries (bolts, washers, grease, hot wash, gaskets, oil)
Big end bearing set
Con/rod nut
Con/rod bolt
Through bolt seals
Valve spring kit
Cam timing pin
Rocker bolt
Ht lead clips
Engine cover (O/S/R)
Engine cover (N/S/R)
Clutch kit
Clutch bolts
Clutch shaft
Clutch shaft seal kit
Clutch slave cylinder
Inlet stack
HT leads
Distributor cap
Rotor arm
Injector overhaul
Gearbox earth strap
Hot air hose
Secondary bypass
Clutch fork
Rear exhaust bracket
Tin plate
Oil pressure sender
Door micro switch
Total (inc VAT) = £6831.
Rebuild costs
Top end overhaul
Head gasket set
Valve guide
Guide inlt
Timing chain
Tensioner (O/S)
Tensioner (N/S)
Piston ring set
Rear crank seal
Front crank seal
o-ring (x2)
return tube
oil filter
Big end bearing set
Con/rod nut
Con/rod bolt
Through bolt seals
Valve spring kit
Cam timing pin
Rocker bolt
Ht lead clips
Clutch kit
Clutch bolts
Clutch shaft
Inlet stack
HT leads
Distributor cap
Rotor arm
Injector overhaul
Gearbox earth strap
Hot air hose
Secondary bypass
Clutch fork
Tin plate
Oil pressure sender
Door micro switch
Read his list. There is a lot more in there than the specific cost of a top end rebuild. That is the problem with the question, as most/all of what was done in addition was smart to do while things were apart and out of the car, but not specifically part of the "top end".
To cut a very long discussion short - In the UK I would say use a shop with a good name - it does make a difference knowing that for example JZ Machtech did the job rather than Dave & Co in East Ham...(no offence Dave!). Budget for around £6K plus clutch and you should be on the safe side. And lets move on....
Ian,
I did had my top rebuilt at the begining of the year at Autostrasse in Essex. I also had a service done, new clutch, (flywheel was fine), and I needed a new cam due to wear which was replaced with a 2nd hand one. Oh, and 2 rockers were worn.
Stripped heads, sent for valve guide removal, seat cutting, and re-fit.
Head studs replaced with Dilivar type.
Piston rings.
Crankcase throughbolt seals.
The dreaded tinwear.
Oil drain return tubes.
Replaced clutch.
Bill came in at £4300 including 17.5% VAT.
It runs really well now, and feels like it's got 50bhp back, plus my garage floor is clean too!
Cheers,
Mark 90C2.
Piston rings.
Replaced clutch.
Cheers,
Mark 90C2.
