964 Forum 1989-1994
Will these wheels fit 964 ?
Old 12-10-2007, 08:11 PM
blueboxster393
blueboxster393's Avatar
Default Will these wheels fit 964 ?
Sorry that I don't have any picture.
They look like the Design 90 rims.
Here is the info:
part#
928.362.1?4.05 -----7.5J x 16 ET65
928.362.1?8.02 -----9J x 16 ET52.3
the "?" is a tiny number engraved in a retangular box too small for my naked eyes.
Owner told me they are from a 944 Turbo S.
There are 2 "buttons" on the inner-side of each rims, about 1 inch in diameter.
Will they fit 964 narrow body ?
They are in good condition (8/10), how much do they worth ?
Old 12-10-2007, 10:51 PM
joey bagadonuts
joey bagadonuts's Avatar
The front offset is excessive by about 10mm, i.e. they'll be tucked under the front fender a bit more than they should be. You might experience some rub at full lock. You should look for wheels that have 50-55mm offsets front and rear.
Are these the wheels you're considering?
Old 12-12-2007, 05:06 PM
blueboxster393
Thanks Joey for your reply.
They look almost the same as D90s, perhaps those are the Mag version.
Can I use wheel spacers for them ? 10mm ok ?
Thanks again..
Old 12-12-2007, 05:14 PM
Cupcar
Cupcar's Avatar
I think those are actually forged aluminum construction and are quite light.
Nice wheels.
The offsets do require 10 mm spacers in front which also requires longer studs, but it is doable easily enough.
Old 12-12-2007, 05:48 PM
meek
meek's Avatar
If they were from a Turbo S they would be 7s up front, not 7.5s; they would still be the forged CS type of alloy, from what you describe. I am guessing from the 2 buttons you refer to that they are 928 fittment with the holes for the tyre pressure sensors (???); are they holes with rubber bungs in??
Old 12-12-2007, 06:26 PM
blueboxster393
some info from pelicanparts :
http://www.pelicanparts.com/cgi-bin/...er=92836215405
How to disable the tire pressure monitoring "buttons" ?
Or simly leave them alone.
How do you compare these to our stock 964 D90s ?
Quick Reply: Will these wheels fit 964 ?
