tear drop areo question
Nov 17, 2007 | 06:23 PM
searched and searched.... my areo mirrors have the usual wires plus 2 purple ones.. I have not seen any posts mentioning purple wires.. what do these connect to?? the car has the 5 wires . I'm working on the passenger side. Hooked up driver side without a problem.
Nov 17, 2007 | 06:33 PM
I don't see any purple wires . . .
Nov 17, 2007 | 06:34 PM
Note that if you have a digital computer in your tach then there is a temperature sensor in one of the mirrors. I had thought it was the driver's side, but perhaps it's the passenger side?
Nov 17, 2007 | 06:38 PM
Nov 17, 2007 | 06:39 PM
Outside temp sensor . . .
No digital comp. but maybe the car they came from had one???
Nov 17, 2007 | 06:40 PM
7 wires?
shld be six . . . or maybe 8 with temp sensor.
I see red, blue, white, black . . looks like the drive motors.
two browns missing . . .two purples present . . .grounds?
What's the 7th?
Nov 17, 2007 | 06:41 PM
red.. white.. blue.. black.. 2 brown.. 2 purple wtf
sorry, not grounds, but the heaters.
Nov 17, 2007 | 06:42 PM
I'll check later years of the wiring diagrams . . .
Nov 17, 2007 | 06:45 PM
965 731242 01 is that a part # ?? 954= turbo right??
Nov 17, 2007 | 06:46 PM
Quote:
Originally Posted by
993c2cab
sorry, did you say you HAVE all of those wires. If so I'll bet the purple are the temp sensor; of course, guessing is no good!
did you have the same set on the other side?
I only have up to 93 and they are the same.
Nov 17, 2007 | 06:50 PM
Yes I have all those 8 wires.. should I just tie off the two purple??
Nov 17, 2007 | 06:53 PM
993c2cab
Now you're over my head. Sorry.
I would try taping those two purples off by them selves, but I can't advise you to, because I don't know for sure. You could blow something.
That number you posted does not compute as a part # on my PET (v6)
